ONTAP EMS reference
repl.out events
repl.out EMS events occur when ONTAP encounters issues associated with out-of-band block transfers and memory allocation.
repl.out.of.band.vbn
Severity
INFORMATIONAL
This message occurs when replication source is asked to send certain blocks out of band because the replica volume did a snapshot restore.
Corrective Action
(None).
Syslog Message
Asked volume '%s%s%s' (DSID %llu) to send out-of-band VVBN %llu; current cursor: %llu; need-many-VBN value: %d.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume.
volDsid (LONGINT): Data set identifier (DSID) of the volume.
oobVVBN (LONGINT): Out-of-band Virtual Volume Block Number (VVBN).
cursor (LONGINT): Current scan cursor.
many (INT): Whether multiple out-of-band VVBNs were asked for.
repl.out.of.memory
Severity
NOTICE
This message occurs when an out-of-memory error is encountered during a SnapMirror® replication operation.
Corrective Action
(None).
Syslog Message
SnapMirror replication transfer encountered an out-of-memory error.
memoryAllocation (STRING): Type of memory allocation.
retry_time_msecs (LONGINT): Retry time in milliseconds.
filename (STRING): Name of the file where the event occurred.
functionName (STRING): Name of the function for which the error occurred.
lineNumber (INT): Line number at which error the occurred.
size (LONGINT): Size of the memory allocation.
