ONTAP EMS reference
repository.cleanup events
Repository.Cleanup.BaseFile
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
ERROR
This message occurs when there is a failure in the Infinite Volume while creating a stream on a nonexistent file, and the base file was left behind in the Vserver.
Corrective Action
Delete the file created from the mounted file system. Example: To delete a file from the Windows cmd shell: C:\Users\Administrator>del Z:\File.txt If the problem persists, contact NetApp technical support.
Syslog Message
Failure happened in the Infinite Volume while creating a stream on a nonexistent file, and the base file (handle: %s) was left behind in Vserver %u.
filehandle (STRING): File handle of the base file that was created.
vserverId (INT): Vserver ID for which the error occurred.
