ONTAP EMS reference
rpl.fixer events
rpl.fixer.launch.autocheck
Severity
NOTICE
This message occurs when SnapMirror® Fixer cannot use the log files generated by a previous SnapMirror 'check' operation. A new SnapMirror 'check' operation will be started.
Corrective Action
(None).
Syslog Message
SnapMirror Fixer could not use the %s log file. A new SnapMirror 'check' operation will be started.
filetype (STRING): Type of SnapMirror checker log file.
