s3.bucket events
s3.bucket EMS events occur when ONTAP encounters issues associated with S3 bucket access and authentication.
s3.bucket.invalid.accessKey
- Severity
ERROR
- Description
This message occurs when the access key is invalid and it has been used to access the S3 bucket/object.
- Corrective Action
Verify that the access key is valid and it has been configured correctly before accessing the bucket/object.
- Syslog Message
S3 %s operation failed while accessing bucket "%s" on S3 server %s because access key "%s" is invalid.
- Parameters
operation (STRING): S3 request name.
bucket (STRING): Name of the S3 bucket.
serverHostname (STRING): Hostname of the S3 server.
accessKey (STRING): Access key.
s3.bucket.notFound
- Deprecated
This event is renamed to "osc.bucket.notFound"
- Severity
ERROR
- Description
This message occurs when the bucket is not found while trying to access an S3 object.
- Corrective Action
Verify that the bucket has been created on the S3 server and the bucket name has been correctly configured in ONTAP before accessing the bucket.
- Syslog Message
Bucket "%s" not found on S3 server %s when performing %s operation.
- Parameters
s3.bucket.signatureMismatch
- Deprecated
This event is renamed to "osc.signatureMismatch"
- Severity
ERROR
- Description
This message occurs when the request signature sent to the S3 server does not match the signature calculated by the server. This could be due to either an incorrect secret key or an internal ONTAP software error in calculating the signature.
- Corrective Action
Verify that the secret access key is configured correctly. If it is correct, contact NetApp technical support for assistance.
- Syslog Message
S3 %s operation server-calculated request signature does not match the signature sent to S3 server %s for bucket "%s".
- Parameters
