ONTAP EMS reference
sm.cascade events
sm.cascade EMS events occur when concurrent SnapMirror® transfers are attempted while in a cascaded scenario, which is not supported.
SM.cascade.concurrency.unsupported
Severity
NOTICE
This message occurs when concurrent SnapMirror® transfers are attempted while in a cascaded scenario, which is not supported. For example, in a relationship A→B→C, when an A→B SnapMirror update is occurring, a B→C SnapMirror update/initialize or a B→C SMTape backup cannot happen at the same time..
Corrective Action
(None).
Syslog Message
%s cascade concurrency is not supported for volume %s until the current transfer has ended.
product (STRING): Either VSM-SMTape cascade or VSM-VSM/SMTape cascade
dstpath (STRING): Replication destination system.
