ONTAP EMS reference
smc.snapmir events
smc.snapmir.dst.invalidType
Severity
ERROR
This message occurs when the destination volume of a SnapMirror® relationship is not of -type Data Protection (DP) and a 'snapmirror initialize' operation is attempted. A volume must be of -type DP to accept a 'snapmirror initialize' operation.
Corrective Action
Use a different volume of -type DP, or use the 'volume create' command to create a new volume of -type DP to use as a destination of the SnapMirror relationship. You cannot modify the type of a volume using the 'volume modify' command.
Syslog Message
Destination volume '%s' of a SnapMirror relationship is not of -type DP. Relationship UUID '%s'.
dstpath (STRING): Path name of the destination volume of the SnapMirror relationship.
relationshipID (STRING): UUID of the snapmirror relationship.
smc.snapmir.frest.clean.fail
Severity
ERROR
This message occurs when SnapMirror® fails to clean up fenced files and file restore restartability information on a volume and no more retries will be attempted.
Corrective Action
Check the reason for the error, take action accordingly and issue 'snapmirror restore -file-restore-clean-up true' on the volume in diagnostic mode.
Syslog Message
File restore clean up on volume '%s' failed with error '%s'.
dstpath (STRING): Path name of the volume.
error (STRING): Error message.
smc.snapmir.init.fail
Severity
ERROR
This message occurs when a SnapMirror® 'initialize' command fails and no more retries will be attempted.
Corrective Action
Check the reason for the error, take action accordingly, and issue the command again.
Syslog Message
Initialize from source volume '%s' to destination volume '%s' failed with error '%s'. Relationship UUID '%s'.
srcpath (STRING): Path name of the source volume of the SnapMirror relationship.
dstpath (STRING): Path name of the destination volume to which the initialize failed.
relationshipID (STRING): Relationship UUID.
smc.snapmir.lrb.auto.resync
Severity
INFORMATIONAL
This message occurs when the latest Snapshot® copy on the SnapMirror® or SnapVault® destination is not the base Snapshot copy and the source volume is read-only. Generally this is a rare event and a local-rollback-based SnapMirror resync will be attempted to automatically recover from this situation. If this event occurs frequently, it is likely that the Snapshot policy on the primary volume in the cascade is deleting Snapshot copies too soon.
Corrective Action
Check the Snapshot policy on the primary (read-write) volume and increase the retention count of the Snapshot copies that must be backed up all the way to the destination.
Syslog Message
Latest Snapshot copy %s on the destination %s is not the base Snapshot copy. Attempting a local rollback based SnapMirror resync to correct this issue.
snap_name (STRING): Name of the latest Snapshot copy on the SnapMirror or SnapVault destination.
dst_path (STRING): Destination volume of the SnapMirror/SnapVault relationship.
smc.snapmir.partnr.noconnect
Severity
ERROR
This message occurs when a SnapMirror® Sync relationship cannot detect the heartbeat signal from the partner node.
Corrective Action
Check the network connection between the source and destination volumes by using the "net interface show -role intercluster -status-admin up" command.
Syslog Message
Source volume "%s" and destination volume "%s" with relationship UUID "%s" lost heartbeat to partner node.
relationship_id (STRING): Relationship UUID.
smc.snapmir.release.fail
Severity
ERROR
This message occurs when a SnapMirror® 'release' command fails and no more retries will be attempted.
Corrective Action
Syslog Message
Release on the source volume '%s' for destination volume '%s' failed with error '%s'. Relationship UUID '%s'.
dstpath (STRING): Path name of the destination volume to which the resync failed.
smc.snapmir.restore.fail
Severity
ERROR
This message occurs when a SnapMirror® 'restore' command fails and no more retries will be attempted.
Corrective Action
Syslog Message
Restore of volume '%s' from volume '%s' failed with error '%s'. Relationship UUID '%s'.
smc.snapmir.resync.fail
Severity
ERROR
This message occurs when a SnapMirror® 'resync' command fails and no more retries will be attempted.
Corrective Action
Syslog Message
Resync from source volume '%s' to destination volume '%s' failed with error '%s'. Relationship UUID '%s'.
smc.snapmir.schd.trans.overrun
Severity
ERROR
This message occurs when a scheduled SnapMirror® transfer overruns the schedule window.
Corrective Action
Check the reason for the schedule overrun and take action accordingly.
Syslog Message
Scheduled transfer from source volume '%s' to destination volume '%s' is taking longer than the schedule window. Relationship UUID '%s'.
dstpath (STRING): Path name of the destination volume of the scheduled transfer.
smc.snapmir.suspending.io
Severity
ALERT
This message occurs when SnapMirror® I/O has been suspended, due either to a loss of connectivity between the SnapMirror Mediator software and partner, or to a denial of network access by the Mediator software.
Corrective Action
Check the status of the connection to the Mediator software by using the "net interface show -role intercluster -status-admin up" command.
Syslog Message
Suspending I/O as with relationship UUID "%s".
error_msg (STRING): Description of the error responsible for the suspension.
smc.snapmir.tb.noconnect
Severity
ERROR
This message occurs when an ONTAP® node is not reachable from the SnapMirror® Mediator software.
Corrective Action
Check the network connection between the source and destination volumes, by using the "network ping -node node_name" command.
Syslog Message
Connection lost to the Mediator software from node: %s, with relationship UUID "%s".
node (STRING): Node name.
mediator_id (STRING): IP of the Mediator.
smc.snapmir.unexpected.err
Severity
ERROR
This message occurs when a SnapMirror® operation encounters an unexpected error.
Corrective Action
Retry the SnapMirror operation. If the problem persists, contact NetApp technical support.
Syslog Message
SnapMirror unexpected error '%s'. Relationship UUID '%s'. Operation UUID '%s'.
operationID (STRING): Operation UUID.
smc.snapmir.unsupp.nvmf
Severity
ERROR
This message occurs when a SnapMirror® operation encounters an NVMe Namespace that is not supported on the destination side.
Corrective Action
Upgrade the destination to a version that supports NVMe Namespace objects.
Syslog Message
SnapMirror unsupported NVMe Namespace. Relationship UUID '%s'.
smc.snapmir.unsupp.nvmf.ns
Severity
ERROR
This message occurs when a SnapMirror® operation encounters a 512-byte block size NVMe namespace that is not supported on the destination.
Corrective Action
Upgrade the destination to a version that supports 512-byte block size NVMe namespace objects.
Syslog Message
SnapMirror unsupported 512-byte block size NVMe namespace. Relationship UUID '%s'.
smc.snapmir.update.fail
Severity
ERROR
This message occurs when a scheduled SnapMirror® transfer fails.
Corrective Action
Check the snapmirror_error log in the destination filer and take action accordingly.
Syslog Message
Snapmirror update from source volume '%s' to destination volume '%s' failed with error '%s'. Relationship UUID '%s'.
dstpath (STRING): Path name of the destination volume to which the snapmirror transfer failed.
