snaplock.legal events
Creating your file...
snaplock.legal.hold.dump.files.op.status
- Severity
NOTICE
- Description
This message occurs on completion of a legal-hold dump-files operation on a SnapLock® compliance volume.
- Corrective Action
(None).
- Syslog Message
A legal-hold dump-files operation with ID %lu ended for litigation %s on volume %s:%s and output path: "%s", with status: "%s", details: "%s". The operation passed on %lu files, failed on %lu files, skipped %lu files and ignored %lu inodes.
- Parameters
operation_id (LONGINT): Operation ID of the legal-hold dump-files operation.
litigation_name (STRING): Name of the litigation.
vserver (STRING): Name of the vserver.
volume (STRING): Name of the SnapLock compliance volume, on which legal-hold dump-files operation is running.
output_path (STRING): Output path of legal-hold dump-files operation.
operation_status (STRING): Status of the legal-hold dump-files operation.
status_details (STRING): Completion string of the legal-hold dump-files operation.
num_files_processed (LONGINT): Total count of files for which legal-hold dump-files operation was performed.
num_files_failed (LONGINT): Total count of files for which legal-hold dump-files operation failed.
num_files_skipped (LONGINT): Total count of files for which legal-hold dump-files operation was skipped.
num_inodes_ignored (LONGINT): Total count of inodes which were ignored by legal-hold dump-files operation because they are not regular files.
snaplock.legal.hold.dump.litigations.job.status
- Severity
NOTICE
- Description
This message occurs on completion of a legal-hold dump-litigations operation.
- Corrective Action
(None).
- Syslog Message
A legal-hold dump-litigations operation with ID %s ended for %s with status: "%s", details: "%s".
- Parameters
job_id (STRING): Job ID of the legal-hold operation.
vserver_and_volume (STRING): Name of the vserver and volume (if any).
job_status (STRING): Status of the legal-hold dump-litigations job.
status_details (STRING): Completion string of the legal-hold dump-litigations job.
snaplock.legal.hold.op.status
- Severity
NOTICE
- Description
This message occurs on completion of a legal-hold begin or end operation on a SnapLock® compliance volume.
- Corrective Action
(None).
- Syslog Message
A legal-hold %s operation with ID %lu ended for litigation %s on path %s in volume %s:%s with status: "%s", details: "%s". The operation passed on %lu files, failed on %lu files, skipped %lu files and ignored %lu inodes.
- Parameters
operation_type (STRING): Type of the legal-hold operation.
operation_id (LONGINT): Operation ID of the legal-hold operation.
path (STRING): Path of the form '/(directory path)' relative to volume root.
volume (STRING): Name of the SnapLock compliance volume, on which legal-hold operation is running.
operation_status (STRING): Status of the legal-hold operation.
status_details (STRING): Completion string of the legal-hold operation.
num_files_processed (LONGINT): Total count of files for which legal-hold operation was performed.
num_files_failed (LONGINT): Total count of files for which legal-hold operation failed.
num_files_skipped (LONGINT): Total count of files for which legal-hold operation was skipped.
num_inodes_ignored (LONGINT): Total count of inodes which were ignored by legal-hold operation because they are not regular files.
