sp.snmp events
Creating your file...
Your file is ready
sp.snmp.traps.off
- Severity
INFORMATIONAL
- Description
This message occurs each time a system boots, if the advanced privilege level in Data ONTAP® was used to disable the SNMP Trap feature of the Service Processor (SP). This message also occurs when the SNMP Trap capability is disabled and a user invokes a Data ONTAP command to use the SP to send an SNMP trap.
- Corrective Action
SP SNMP Trap support is currently disabled. To enable this feature, set the 'sp.snmp.traps' option to On.
- Syslog Message
SP's SNMP Trap support is currently disabled. Set option 'sp.snmp.traps' to 'On' to enable this feature.
- Parameters
(None).
