telnet.socket events
telnet.socket EMS events occur when ONTAP encounters issues associated with telnet socket operations.
telnet.socket.failure
- Severity
ERROR
- Description
This message occurs when telnet could not create a socket.
- Corrective Action
Change the option 'telnet.port', to try to create another socket.
- Syslog Message
Telnet socket error: %s.
- Parameters
reason (STRING): Reason why telnet could not create a socket.
telnet.socket.timeout
- Severity
ERROR
- Description
This message occurs when a telnet daemon socket was not able to send data to the telnet or ssh client after multiple attempts. This message can also occur when the client window size is set to zero by the telnet or ssh client.
- Corrective Action
Check the window size of the telnet/ssh client by typing "netstat" on the storage system. If it is zero, close the client and restart that session. Otherwise check for any network problem between telnet/ssh client and storage system and correct it.
- Syslog Message
Telnet daemon socket timed out for the %s connection.
- Parameters
conntype (STRING): The type of connection that timed out. The connection type can be an interactive SSH connection or a telnet connection.
