vm.host events
vm.host EMS events occur when a VM is paused by the hypervisor.
vm.host.error
- Severity
EMERGENCY
- Description
This message occurs when a VM is paused by the hypervisor. The backing datastore might have been filled or connectivity to the datastore might have been lost. Corrective actions should be performed as soon as possible.
- Corrective Action
Check the hypervisor logs to determine whether the backing datastore is full or connectivity to the datastore was lost, and then take the appropriate corrective action.
- Syslog Message
The VM is paused possibly due to a full datastore or connectivity to the datastore might have been lost. Check the hypervisor logs for errors, and then perform any necessary corrective actions as soon as possible.
- Parameters
(None).
