ONTAP EMS reference
vol.inconsistent events
vol.inconsistent EMS events occur when the "vol inconsistent" command is used to modify a volume's state.
vol.inconsistent.modify
Severity
INFORMATIONAL
This message occurs when the "vol inconsistent" command is used to modify a volume's state.
Corrective Action
(None).
Syslog Message
Volume %s: 'vol inconsistent' command used to change inconsistent state to '%s'.
vol (STRING): Name of the volume.
state (STRING): State of the action "set" or "clear".
