vserver.mcc events
vserver.mcc.repl.failed
Severity
ERROR
This message occurs in a MetroCluster™ configuration when an attempt to create a Vserver on the partner cluster fails.
Corrective Action
Run the 'metrocluster vserver show' command, and follow the corrective action specified in the output.
Syslog Message
Vserver %s cannot be created on the partner cluster.
vserver_name (STRING): Name of the Vserver.
vserver.mcc.start.failed
Deprecated
Deprecated as of version 9.2.0 as this EMS is not required.
Severity
ALERT
This message occurs when a sync-destination Vserver fails to get started during a MetroCluster(tm) switchover operation or a sync-source Vserver fails to get started during a MetroCluster switchback operation.
Corrective Action
Start the Vserver which failed to get started during MetroCluster switchover/switchback.
Syslog Message
Failed to start the Vserver %s during Metrocluster switchover/switchback operation.
vserver_name (STRING): Name of the vserver which failed to get started.
vserver.mcc.stop.failed
Deprecated
Severity
ERROR
This message occurs when a sync-destination Vserver fails to get stopped during a MetroCluster switchback operation.
Corrective Action
Stop the Vserver which failed to get stopped during MetroCluster switchback.
Syslog Message
Failed to stop the Vserver %s during MetroCluster switchback operation.
vserver_name (STRING): Name of the vserver which failed to get stopped during MetroCluster switchback.
