The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
wafl.cdemap events
Creating your file...
Your file is ready
wafl.cdemap.repaired.metafile
- Severity
ERROR
- Description
This message occurs when an inconsistency is discovered in one of the metafile blocks. The inconsistency is automatically repaired upon detection.
- Corrective Action
(None).
- Syslog Message
Inconsistent block (%s) found in %s metafile on aggregate (%s). Repaired.
- Parameters
state (STRING): A description of the metafile block that was found to be inconsistent.
metafile_name (STRING): Name of the metafile.
aggr (STRING): Name of the aggregate.
