ONTAP EMS reference
callhome.hostport events
callhome.hostport EMS events occur when ONTAP encounters issues associated with host ports being bypassed by ESH or disabled by IOM due to excessive errors.
callhome.hostport.bypass
Severity
ALERT
This message occurs when an Embedded Switched Hub (ESH) bypasses a host port due to excessive errors on the port. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Depending on your system configuration, you might need to replace the ESH Module or replace the Fibre Channel cable to the host port. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for HOST_PORT_FAIL - Bypassed by ESH
subject (STRING): AutoSupport subject or title for this event.
callhome.hostport.disable
Severity
ALERT
This message occurs when an I/O Module (IOM) disables a host port due to excessive errors on the port. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Depending on your system configuration, you might need to replace the IOM or ensure that a good cable is attached to the host port. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for HOST_PORT_FAIL - Disabled by IOM
