cloud.aws events
cloud.aws EMS events occur when ONTAP encounters issues associated with Amazon Web Services (AWS) Identity and Access Management (IAM) credentials.
cloud.aws.iamCredsExpired
- Severity
ERROR
- Description
This message occurs when the IAM Role thread acquires Amazon Web Services (AWS) Identity and Access Management (IAM) role-based credentials that have already expired. The credentials are acquired from the AWS metadata server using the IAM role, and are used in signing API requests to AWS S3.
- Corrective Action
Log in to the AWS EC2 Management Console, click on the 'Instances' page, and then find and check the health of the instance pertaining to this ONTAP Cloud deployment. Also verify that the AWS IAM role associated with the instance exists and grants proper privileges to the instance.
- Syslog Message
ONTAP acquired AWS credentials associated with the AWS IAM role named '%s' on the AWS metadata server that have already expired. Node %s.
- Parameters
iamRole (STRING): Name of the IAM role associated with this ONTAP Cloud® instance.
nodeUuid (STRING): UUID of the node.
cloud.aws.iamCredsInvalid
- Severity
ERROR
- Description
This message occurs when the system acquires Amazon Web Services (AWS) Identity and Access Management (IAM) role-based credentials that are not valid.
- Corrective Action
In the AWS EC2 Management Console, find and check the health of the instance pertaining to this ONTAP Cloud deployment. Also, verify that the AWS IAM role associated with the instance exists and grants proper privileges to the instance.
- Syslog Message
AWS credentials that were acquired by ONTAP are not valid. AWS IAM role: %s. Node: %s.
- Parameters
iamRole (STRING): Name of the IAM role associated with this ONTAP Cloud instance.
cloud.aws.iamCredsNotFound
- Severity
ERROR
- Description
This message occurs when the cloud credentials thread cannot acquire Amazon Web Services (AWS) Identity and Access Management (IAM) role-based credentials from the AWS metadata server. The credentials are used in signing API requests to AWS S3.
- Corrective Action
Log in to the AWS EC2 Management Console, click on the 'Instances' page, and then find and check the health of the instance pertaining to this Cloud Volumes ONTAP® deployment. Also verify that the AWS IAM role associated with the instance exists and grants proper privileges to the instance.
- Syslog Message
ONTAP cannot acquire credentials associated with the AWS IAM role or GCP Service Account named '%s' on the metadata server. Node %s.
- Parameters
iamRole (STRING): Name of the AWS IAM role associated associated with this Cloud Volumes ONTAP® instance.
cloud.aws.iamNotInitialized
- Severity
NOTICE
- Description
This message occurs when a module attempts to access Amazon Web Services (AWS) Identity and Access Management (IAM) role-based credentials from the cloud credentials thread before the cloud thread is finished initializing.
- Corrective Action
Wait for the cloud credential thread, and by extension the system, to complete initialization.
- Syslog Message
A module attempted to access credential information before the cloud credential thread initialized on node %s.
- Parameters
cloud.aws.iamRoleInvalid
- Severity
ERROR
- Description
This message occurs when the system acquires an Amazon Web Services (AWS) Identity and Access Management (IAM) role on the AWS metadata server that is not valid.
- Corrective Action
- Syslog Message
IAM role "%s" on the AWS metadata server is not valid for this ONTAP instance (node %s).
- Parameters
cloud.aws.iamRoleNotFound
- Severity
ERROR
- Description
This message occurs when the IAM Role thread cannot find an Amazon Web Services (AWS) Identity and Access Management (IAM) role on the AWS metadata server. The IAM role is needed to obtain role-based credentials used in signing API requests to AWS S3.
- Corrective Action
Log in to the AWS EC2 Management Console, click on the 'Instances' page, and then find and check the health of the instance pertaining to this ONTAP Cloud® deployment. Also verify that the AWS IAM role associated with the instance exists.
- Syslog Message
ONTAP node %s cannot find an IAM role on the AWS metadata server.
- Parameters
cloud.aws.metadataConnFail
- Severity
ERROR
- Description
This message occurs when the IAM Role thread cannot establish a communication link with the Amazon Web Services (AWS) metadata server. Communication must be established to acquire the necessary AWS Identity and Access Management (IAM) role-based credentials used in signing API requests to AWS S3.
- Corrective Action
Log in to the AWS EC2 Engine Management Console, click on the 'Instances' page, and then find and check the health of the instance pertaining to this Cloud Volumes ONTAP® deployment.
- Syslog Message
ONTAP cannot communicate with the AWS metadata server needed to acquire IAM role-based or Service Account based credentials for access to AWS S3 Storage. Error returned: %s Node: %s
- Parameters
error (STRING): Error code and string, if applicable.
