ONTAP EMS reference
cluster.network events
cluster.network EMS events occur when a two node cluster transitions between a switched and switchless configuration.
cluster.network.config
Severity
NOTICE
This message occurs when a two node cluster transitions between a switched and switchless configuration.
Corrective Action
(None).
Syslog Message
The cluster network configuration transitioned to %s.
current_configuration (STRING): Displays if the current configuration is switched or switchless.
