connectx.ibretimerfailcount events
connectx.ibretimerfailcount EMS events occur when InfiniBand retimer programming fails due to one of the following reasons: InfiniBand device not found, GPIO read failure or retimer chip failure.
connectx.IbRetimerFailCount
- Severity
ERROR
- Description
This message occurs when InfiniBand retimer programming fails due to one of the following reasons: InfiniBand device not found, GPIO read failure or retimer chip failure.
- Corrective Action
Automatic retry of InfiniBand retimer programming will be done and an AutoSupport(tm) message will be generated if two retries fail.
- Syslog Message
InfiniBand retimer programming failed on port %s due to %s.
- Parameters
port_str (STRING): InfiniBand port in which the cable is plugged.
reason (STRING): Reason for the failure of InfiniBand retimer programming.
