coredump.spare events
coredump.spare.abort
- Severity
INFORMATIONAL
- Description
This message occurs when coredump attempts to terminate any sparecore dump that might be in progress on the partner. This process can take up to 60 seconds. During this time, other coredump operations are not serviced.
- Corrective Action
(None).
- Syslog Message
Pausing to abort partner sparecore dump because %s.
- Parameters
reason (STRING): Reason for aborting the partner sparecore dump.
coredump.spare.abort.failed
- Severity
ERROR
- Description
Unable to reserve the sparecore disk. This disk cannot be used by RAID until it is successfully reserved.
- Corrective Action
If the other partner can be booted, do a giveback. Otherwise, periodic attempts will automatically be made to reserve the disk in question.
- Syslog Message
Sparecore disk could not be reserved
- Parameters
(None).
coredump.spare.abort.release
- Severity
NOTICE
- Description
This message occurs when the system enounters an error while trying to release the disk reservation from a disk.
- Corrective Action
(None).
- Syslog Message
Could not release disk reservation from disk %s (0x%x)
- Parameters
diskname (STRING): Name of the disk whose disk reservation could not be released.
diskid (INTHEX): ID of the disk whose disk reservation could not be released.
coredump.spare.dump
- Severity
INFORMATIONAL
- Description
This message occurs to tell you which disk was used as the sparecore disk at dumpcore time.
- Corrective Action
(None).
- Syslog Message
Disk %s was used as the sparecore disk at dumpcore time.
- Parameters
diskname (STRING): Name of the sparecore disk.
coredump.spare.invalid.size
- Severity
ERROR
- Description
This message occurs when coredump subsystem encounters a spare disk with an invalid size. If an unsaved core file exists on this disk, it will be deleted because it can no longer be saved.
- Corrective Action
Run the "storage disk show -disk disk_name" command to make sure that the disk is still connected as a spare disk. If so, replace the disk. If not, the disk is part of an aggregate or is in the process of being assigned to one, and no action is required.
- Syslog Message
sparecore disk: %s has invalid size: %llu, skipping it from all coredump subsystem operations
- Parameters
disk (STRING): Name of the disk.
size (LONGINT): Size available on the disk, reported by RAID.
