cs.create events
cs.create.inprogress
- Severity
ALERT
- Description
This message occurs when there is an attempt to release SnapMirror resources for a volume as a result of volume delete while a Cloud Snapshot create operation is in progress.
- Corrective Action
Ensure no Cloud Snapshot create opeartion is in-progress when the volume is deleted. Either abort the create operation or wait for the creation to complete before deleting the volume.
- Syslog Message
Failed to delete the volume "%s" as one or more Cloud Snapshot operations are in progress. Number of Cloud Snapshot operations in progress: "%d".
- Parameters
volumeUUID (STRING): UUID of the volume.
in_transfer_snap_count (INT): Number of Cloud Snapshot create in-progress.
