ONTAP EMS reference
dbs.exception events
dbs.exception EMS events occur when the Distributed Block Store (DBS) is unable to process a cluster fault.
dbs.exception
Severity
ERROR
This message occurs when the Distributed Block Store (DBS) is unable to process a cluster fault.
Corrective Action
Wait 60 minutes and check that the fault status has changed to Resolved. If the condition persists, contact NetApp technical support.
Syslog Message
DBS has detected a software exception. Cluster fault type %s, fault ID %u, status %u. %s
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the exception.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
