ONTAP EMS reference
dbs.file events
dbs.file EMS events occur when ONTAP encounters issues associated with Distributed Block Store (DBS) container file system capacity or write access.
dbs.file.system.capacity.low
Severity
ERROR
This message occurs when the Distributed Block Store (DBS) detects the mounted container file system ("/", "/persist", "/var/log") has capacity below 5 percent.
Corrective Action
Add additional filesystem capacity to the node or remove any unneeded files until the fault is cleared.
Syslog Message
DBS has detected low filesystem free space on node %u/%s. Cluster fault type %s, fault ID %u, status %u. %s
nodeID (INT): Node ID number of the associated node. It is "0" if there is no associated node.
nodeUuid (STRING): Universal unique identifier (UUID) of the associated node. If there is no associated node, zeroes display.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
dbs.file.system.read.only
Severity
ALERT
This message occurs when Distributed Block Store (DBS) detects a mounted container file system ("/", "/persist", "/var/log") that should be writeable is marked as read-only.
Corrective Action
Verify required node file systems ("/", "/persist", "/var/log") are writeable. If not, resolve this issue. Contact NetApp technical support if cause cannot be found.
Syslog Message
DBS has detected a file system is read-only. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
nodeUuid (STRING): Node UUID string of the associated node.
cfDetails (STRING): Details of the file system set to read-only.
