dbs.limit events
dbs.limit EMS events occur when a Distributed Block Store (DBS) limit event occurs, such as reaching the recommended or maximum number of volumes or virtual volumes.
dbs.limit
- Severity
NOTICE
- Description
This message occurs when a Distributed Block Store (DBS) limit event occurs, such as reaching the recommended or maximum number of volumes or virtual volumes. If the original DBS event specifies multiple drives, then an EMS event is generated for each drive.
- Corrective Action
(None).
- Syslog Message
A DBS limit event %s of type %s occurred for Service ID %u on node %u/%s. Drive ID = %u/%s. Event ID = %u.
- Parameters
evtMessage (STRING): Description of the DBS event, including context details.
evtType (STRING): Type of the original DBS event.
serviceID (INT): Service ID that identifies the associated DBS service. It is 0 if there is no associated service.
nodeID (INT): Node ID number of the associated node. It is 0 if there is no associated node.
nodeUuid (STRING): Generated Universal Unique Identifier (UUID) of the associated node. It displays zeroes if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is 0 if there is no associated drive.
driveUuid (STRING): Generated UUID of the associated drive. It displays zeroes if there is no associated drive.
evtID (INT): DBS event ID number.
evtDetails (STRING): Specific details of the DBS event. It displays as a string, in JSON format, or is empty.
