ONTAP EMS reference
fmmb.add events
fmmb.add EMS events occur when the HA mailbox is attempting to add a mailbox disk and a problem occurred.
fmmb.add.problem
Severity
ERROR
This event is issued when the HA mailbox is attempting to add a mailbox disk and a problem occurred.
Corrective Action
(None).
Syslog Message
Error attempting to add disk %s as a %s HA mailbox disk.
disk (STRING): The name of the disk. If the disk name is not available, a ?.? will be used.
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
