      fmmb.blobnotfound events
fmmb.BlobNotFound
- Severity
ALERT
 - Description
This message occurs when a mailbox 'blob' is not read from the on-disk mailbox data structure. A 'blob' is a piece of data which has been stored for a non-High Availability (HA) Data ONTAP® subsystem in the mailbox.
 - Corrective Action
If the blob id is "3" and this is a 2-node cluster, use the 'cluster ha modify -configure' command to unconfigure ha and then reconfigure it.
 - Syslog Message
(None).
 - Parameters
blob_id (INT): 'blob' ID.
owner (STRING): Owner of the blob, either PARTNER or LOCAL.
reason (STRING): Reason for the problem.
