ONTAP EMS reference
fpolicy.outage events
fpolicy.outage EMS events occur when ONTAP encounters issues associated with FPolicy network outages and notification handling.
fpolicy.outage.file.invalid
Severity
ERROR
This message occurs when file creation fails under the configured resiliency directory path.
Corrective Action
Check the configured resiliency directory path. To find the configured resiliency directory path by using the "vserver fpolicy policy external-engine show" command.
Syslog Message
Failed to create file under configured resiliency directory path of FPolicy external engine "%s" for policy "%s". Reason: %s.
engine (STRING): FPolicy external engine.
policy (STRING): FPolicy policy.
reason (STRING): Reason for the failure.
fpolicy.outage.msg.lost
Severity
ERROR
This message occurs when the send operation fails for the network outage notification.
Corrective Action
Find the file in the configured resiliency directory path.
Syslog Message
Failed to send outage notification message to any FPolicy server for policy "%s" and path "%s".
path (STRING): File path.
fpolicy.outage.msg.success
Severity
NOTICE
This message occurs when a network outage notification is successfully sent.
Corrective Action
(None).
Syslog Message
Outage notification message sent to at least one FPolicy server for policy "%s" and file path "%s".
fpolicy.outage.over
Severity
NOTICE
This message occurs when the FPolicy external engine, acting asynchronously and with resiliency support enabled, is reconnected after a network outage.
Corrective Action
(None).
Syslog Message
The network outage (duration: "%llu" sec) is over. At least one FPolicy server is now connected successfully for FPolicy external engine "%s" of policy "%s".
Duration (LONGINT): Network outage duration in seconds.
engine (STRING): Asynchronous FPolicy external engine.
fpolicy.outage.start
Severity
NOTICE
This message occurs when the FPolicy external engine, acting asynchronously and with resiliency support enabled, is disconnected due to a network outage.
Corrective Action
(None).
Syslog Message
Network outage for FPolicy external engine "%s" of policy "%s".
fpolicy.outage.timeout
Severity
NOTICE
This message occurs when the maximum notification retention duration for the FPolicy external engine expires, and the engine is configured to operate asynchronously with resiliency support enabled. The storage controller stores no more notifications.
Corrective Action
(None).
Syslog Message
Maximum notification retention time has expired for FPolicy external engine "%s" of policy "%s".
fpolicy.outage.write
Severity
NOTICE
This message occurs when FPolicy cannot store file notifications using the configured resiliency directory path.
Corrective Action
(None).
Syslog Message
Failed to store notifications in configured resiliency directory path of FPolicy external engine "%s" for policy "%s". Reason: %s.
fpolicy.outage.writes.lost
Severity
ERROR
This message occurs when FPolicy fails multiple consecutive times to store file notifications using the configured resiliency directory path.
Corrective Action
Syslog Message
Unable to store notifications in configured resiliency directory path of FPolicy external engine "%s" for policy "%s".
