ONTAP EMS reference
ha.mbxresvreleasedelay events
ha.mbxresvreleasedelay EMS events occur when the takeover node cannot release a disk reservation for a mailbox disk in preparation for a giveback event.
ha.mbxResvReleaseDelay
Severity
NOTICE
This message occurs when the takeover node cannot release a disk reservation for a mailbox disk in preparation for a giveback event. The mailbox reservation release will be automatically retried after a few minutes.
Corrective Action
The mailbox reservation release will be automatically retried after a few minutes. If this problem persists and "storage failover giveback" is not run automatically or cannot be run manually, release the mailbox disks reservations manually using maintenance mode.
Syslog Message
Problem releasing reservation for mailbox disk attached to node with System ID %d. Disk name %s, disk owner %s, disk UUID: %s, status: %d.
physical_location (LONGINT): System ID of the node directly attached to the mailbox disk on which the reservation release failure occurred.
disk_name (STRING): Name of the disk for which the reservation release failed.
mbx_disk_owner (STRING): Owner of the mailbox disk where the reservation release failed. Values are Local Node or Partner Node.
disk_uid (STRING): Unique identifier of the disk where the reservation release failed.
status (INT): Reservation release status code.
