ONTAP EMS reference
ha.takeoverimpnotdef events
ha.takeoverimpnotdef EMS events occur when the partner node is down and it is currently impossible to perform a takeover.
ha.takeoverImpNotDef
Severity
ERROR
This message occurs when the partner node is down and it is currently impossible to perform a takeover.
Corrective Action
Check the reason string and repair the problem reported.
Syslog Message
Takeover of the partner node is impossible due to reason %s.
reason (STRING): Reason the takeover is currently impossible.
