hwaccel.init events
hwaccel.init EMS events occur when initialization of a hardware accelerator fails due to an unexpected software error.
hwaccel.init.failed
- Severity
ALERT
- Description
This message occurs when initialization of a hardware accelerator fails due to an unexpected software error. The system falls back to software acceleration and continues to function normally, but expect reduced performance.
- Corrective Action
Rebooting the system might clear the problem. The problem might be caused by a software bug, but is likely indicative of a hardware failure. If the problem persists, contact NetApp technical support.
- Syslog Message
Initialization of hardware accelerator %s fails due to unexpected software error %s:%d.
- Parameters
devName (STRING): Name of the acceleration device; for example, "qat0".
module (STRING): Name of the software module or driver.
error (INT): Module-specific error code.
