ipmultipath.setup events
ipmultipath.setup.bindFailed
- Severity
ERROR
- Description
This message occurs during IP Multipath connection setup, when the IP Multipath listener process cannot bind to any IP address of the source.
- Corrective Action
The source host information provided to IP Multipath is probably incorrect. Correct the configuration information and retry.
- Syslog Message
IP Multipath failed to bind to %s.
- Parameters
src (STRING): Host name on which the failure occurred.
ipmultipath.setup.connFailed
- Severity
ERROR
- Description
This message occurs during IP Multipath connection setup, when it cannot connect to the remote end point.
- Corrective Action
The destination host information provided to IP Multipath is incorrect or the remote host is unreachable. Correct configuration information and retry. If the remote host is unreachable, IP Multipath automatically establishes the connection after the problem is corrected.
- Syslog Message
IP Multipath failed to connect to %s.
- Parameters
dst (STRING): Host name of the remote host.
