master.new events
master.new EMS events occur when the connection state from a node to the current cluster master has changed.
master.new.connection.state
- Severity
NOTICE
- Description
This message occurs when the connection state from the associated node to current cluster master has changed.
- Corrective Action
(None).
- Syslog Message
Service ID %u on node ID %u (UUID: %s) has a new MVIP address connection state "%s" to cluster master with service ID %u. The best connection state is "%s".
- Parameters
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
currentState (STRING): Current management virtual IP (MVIP) address connection state.
lastKnownClusterMasterServiceID (INT): Service ID number of the cluster master last known by this node.
highestState (STRING): Best MVIP address connection state reached since the node connected to current cluster master.
