nblade.tlsconfigerror events
nblade.tlsconfigerror EMS events occur when the client is trying to use NFS over TLS (Transport Layer Security), but it is disabled on the NFS server side.
Nblade.TLSConfigError
- Severity
ERROR
- Description
This message occurs when the client is trying to use NFS over TLS (Transport Layer Security), but it is disabled on the NFS server side.
- Corrective Action
Enable the configuration by running "nfs tls interface enable" command.
- Syslog Message
Failed to create NFS over TLS (Transport Layer Security) connection from client IP address:"%s", because NFS over TLS configuration not found for SVM:"%s", LIF:"%s".
- Parameters
clientIpAddress (STRING): Client IP address.
vsName (STRING): Storage virtual machine (SVM) name.
lifIpAddress (STRING): LIF IP address of NFS server.
