netif.eepromreadfailed events
netif.eepromReadFailed
Severity
ERROR
This message occurs when there is a failure in reading the electronically erasable programmable read-only memory (EEPROM) for a network interface. The interface is not initialized.
Corrective Action
Rebooting the system might clear the problem. The problem might be caused by a software bug and should be reported to NetApp technical support.
Syslog Message
Failure in reading EEPROM for network interface %s.
ifName (STRING): Name of the network interface; for example, "e8a".
