ONTAP EMS reference
nvdimm.excessive events
nvdimm.excessive EMS events occur when excessive correctable error-correcting code (ECC) memory errors are reported by the NVDIMM controller.
nvdimm.excessive.cecc.errs
Severity
ALERT
This message occurs when excessive correctable error-correcting code (ECC) memory errors are reported by the NVDIMM controller.
Corrective Action
Use the "system environment sensors show -hidden true" clustershell command to view the current "NV Correctable ECC Count" value. Contact NetApp technical support for further assistance.
Syslog Message
Excessive correctable ECC errors in the NVDIMM in slot-%d. Count: %d.
slot (INT): NVDIMM slot location.
count (INT): CECC count.
