nvdimm.fw events
nvdimm.fw.upgrade.failure
- Severity
ERROR
- Description
This message occurs when NVDIMM controller firmware failed to upgrade.
- Corrective Action
Power-cycle the controller and reboot ONTAP to attempt the firmware update again. If the error persists, contact NetApp technical support for assistance.
- Syslog Message
NVDIMM controller in slot-%d failed to upgrade firmware because of %s.
- Parameters
slot (INT): NVDIMM slot location.
error (STRING): Reason for upgrade failure, which could be: 1. the image file does not exist or is corrupted 2. it is unable to enter update mode 3. it is unable to clear update mode 3. the firmware image transfer failed 4. of a CRC mismatch with the transferred image 5. it failed to validate or commit the image 6. it failed to restart after the image upgrade
nvdimm.fw.upgrade.succeed
- Severity
NOTICE
- Description
This message occurs when the NVDIMM controller sucessfully upgrades its own firmware image..
- Corrective Action
(None).
- Syslog Message
NVDIMM controller firmware in slot-%d was upgraded to %s.
- Parameters
version (STRING): New firmware version.
