ONTAP EMS reference
perfstatd.start events
perfstatd.start EMS events occur when the perfstat daemon (perfstatd) startup fails.
perfstatd.start.unsuccessful
Severity
ERROR
This message occurs when the perfstat daemon (perfstatd) startup fails. This failure impacts the continuous archiving of performance data that technical support uses to troubleshoot performance issues.
Corrective Action
The startup failure might be due to improper permissions for the '/mroot/etc/log' directory or a full disk. Verify that the permissions of the '/mroot/etc/log' directory are 'rwxr-xr-x' by executing the 'fsecurity show /vol/vol0/etc/log' command from the nodeshell. Verify that the '/mroot' file system is not full. After fixing the cause of the failure, restart perfstatd by executing the 'spmctl -e -h perfstatd' command from the freebsd shell.
Syslog Message
The perfstat daemon startup failed.
(None).
