ONTAP EMS reference
replication.src events
replication.src.err
Severity
ERROR
This message occurs when the system detects an error on a SnapMirror® or SnapVault® source volume or qtree.
Corrective Action
(None).
Syslog Message
%s: source transfer from %s to %s:%s : %s.
rtype (STRING): Replication type (SnapMirror, SnapVault, and so on.).
srcpath (STRING): Replication source volume or qtree.
dstfiler (STRING): Replication destination system.
dstpath (STRING): Replication destination volume or qtree.
error (STRING): Specific error message.
replication.src.inconsistent.snapmap
Severity
ERROR
This message occurs when a replication source engine encounters a disk error in a snapmap block. Replication transfer will abort.
Corrective Action
Run wafliron as soon as possible, and then Contact NetApp technical support.
Syslog Message
WAFL metadata inconsistent due to disk errors in volume %s. The affected Snapshot copy ID is %d (level: %d). Aborting transfer.
volname (STRING): Aggregate, traditional volume, or flexible volume name.
snapid (INT): Snapshot(tm) copy ID.
level (INT): Buffer level.
replication.src.throttleChange
Severity
NOTICE
This event is issued when the replication source, receives a request from the destination to change the current throttle value.
Corrective Action
(None).
Syslog Message
Throttle value changed to %d Kbytes/s for destination %s:%s
throttle (INT): The new throttle value.
dstfiler (STRING): The SnapMirror destination filer
dstpath (STRING): The SnapMirror destination volume or qtree
replication.src.throttleChange.err
Severity
ERROR
This event is issued when the replication source, receives a request from the destination to change the current throttle value, but failed to complete the operation.
Corrective Action
(None).
Syslog Message
Failed to change throttle value to %d Kbytes/s for destination %s:%s : %s
error (STRING): The error message
replication.src.unknownCommand
Severity
NOTICE
This event is issued when the replication source, SnapMirror or SnapVault, receives a request from the destination which it does not understand. This can be seen when changes are made to the negotiation phase internally during development. This error message should NEVER show up on customer builds.
Corrective Action
This message is normally seen after upgrading the source or the destination. ONTAP version mismatch between the source and destination can cause this. One should not see this problem if the source and destination filers are running the same version of ONTAP.
Syslog Message
Replication source received an unknown command from the destination. This might be due to Data ONTAP version mismatch between the source and destination.
(None).
