      se.scan events
se.scan.filecg.stopped
- Severity
ERROR
 - Description
This message occurs when the Single Instance Storage (SIS) scanner is attempting to recompress file-based compression (secondary compression or 8k/16K/32K adaptive compression) in a volume and there is insufficient space in the volume.In this case the recompress operation is halted to allow you to check and enable the autogrow/ autodelete setting on the volume if it is not already enabled.
 - Corrective Action
Consider rerunning the operation manually after enabling the autogrow/autodelete setting on the volume.
 - Syslog Message
Recompression of file based compressed blocks to container level compression is halted because volume '%s' might run out of space during this procedure. SIS scan type '%s'.
 - Parameters
volume (STRING): Volume name.
scan_type (STRING): SIS scan type.
