secd.rpc events
secd.rpc.authRequest.blocked
- Severity
ALERT
 - Description
This message occurs when a user with the same domain and same client IP address is blocked due to continuous authentication requests with an invalid login password.
 - Corrective Action
Check if there is an unexpected increase in the number of authentication requests with an invalid login password from a particular CIFS client. Use "statistics show -raw -object secd -instance secd -counter num_rpcs_blocked_due_to_wrong_password" command to check the number of clients blocked due to an invalid password.
 - Syslog Message
Too many CIFS authentication attempts with an invalid password from a client with IP "%s", user name "%s" and domain "%s" on SVM "%s".
 - Parameters
clientIP (STRING): IP address of the client that has been blocked.
userName (STRING): User who is trying to mount with an invalid password.
domain (STRING): Domain to which the user belongs.
vserverName (STRING): Storage virtual machine(SVM) associated with this operation.
secd.rpc.server.ready
- Severity
INFORMATIONAL
 - Description
This message occurs when SecD successfully loads the configuration and is ready to serve all RPCs.
 - Corrective Action
(None).
 - Syslog Message
SecD is ready to serve all RPCs.
 - Parameters
(None).
secd.rpc.server.request.dropped
- Severity
ERROR
 - Description
This message occurs when a remote procedure call(RPC) is dropped by SecD due to a lack of memory space. It might occur either when SecD receives too many requests than it can handle or when a number of requests have accumulated due to server connectivity issues.
 - Corrective Action
Check whether there is an unexpected increase in the number of authentication requests from NFS/CIFS clients. Verify that there are no connectivity issues to the external servers like DNS, LDAP, and DC.
 - Syslog Message
RPC "%s" that was sent from "%s" was dropped by SecD due to a lack of memory space.
 - Parameters
rpcName (STRING): Name of the RPC that has been dropped.
callerName (STRING): Caller of the RPC that has been dropped.
