sis.changelog events
sis.changelog.full
- Severity
ERROR
- Description
This message occurs when the Single Instance Storage (SIS) change logging metafile is full. Change logging is stopped. New writes to the volume will not be change logged until the next SIS operation.
- Corrective Action
Issue the 'sis start' command on the volume to process existing changelogs. To process changelog files more frequently before they reach full, adjust the SIS operation schedule with the 'sis config -s' command. If there is significant loss of savings, then run the 'sis start -s' command, allowing it to run to completion.
- Syslog Message
SIS change logging metafile for volume %s%s%s is full.
- Parameters
host (STRING): Owning host of the volume.
vol (STRING): Name of the volume.
volident (STRING): Uniquely identifies the volume when the volume name itself is insufficient.
sis.changelog.noinit
- Severity
ERROR
- Description
This event is issued when the change logging operation could not be initialized on a SIS volume.
- Corrective Action
Run "sis on" command to reinitialzie the change logging operation.
- Syslog Message
Change logging operation on volume %s%s could not be initialized: %s.
- Parameters
vol (STRING): The name of the volume
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
err (STRING): Error message
sis.changelog.noload
- Severity
NOTICE
- Description
This event is issued when prior change logging metafiles could not be reused during the initialization. New metafiles will be created for the operation.
- Corrective Action
(None).
- Syslog Message
Prior Change logging metafiles on volume %s%s could not be reused.
- Parameters
sis.changelog.truncate
- Severity
NOTICE
- Description
This message occurs when the Single Instance Storage (SIS) change logging metafile is truncated as part of ADS session.
- Corrective Action
(None).
- Syslog Message
Prior Change logging metafiles on volume %s%s are truncated.
- Parameters
