ONTAP EMS reference
snaplock.invalid events
snaplock.invalid EMS events occur when an invalid autocommit period value is found on a SnapLock® volume.
snaplock.invalid.autocommit
Severity
ERROR
This message occurs when an invalid autocommit period value is found on a SnapLock® volume. ONTAP® 9.4 software and later releases have a maximum autocommit period value of 10 years. If this maximum is exceeded, autocommit is disabled on the volume.
Corrective Action
Correct the autocommit period on the SnapLock volume by using the "volume snaplock modify" command or the "volume-set-snaplock-attrs" Zephyr API.
Syslog Message
Disabling autocommit on SnapLock volume %s%s on the Vserver with ID %s because the autocommit period exceeded the maximum of 10 years.
volume (STRING): Name of the SnapLock volume with invalid autocommit period value.
app (STRING): Application Name.
volident (STRING): Unique identifier of the volume when the volume name itself is insufficient.
