tapemc.alias events
tapemc.alias.addFail
- Severity
ERROR
- Description
This message occurs when the automatic addition of a tape or medium changer alias fails. Data ONTAP® might attempt to add aliases automatically at boot or when devices are added, if it determines that the devices have no existing aliases.
- Corrective Action
Check the tape and medium changer aliases to ensure that they specify the desired devices. You can view, add, or delete aliases using the "storage alias/unalias" (7-Mode or Cluster-Mode nodeshell) commands.
- Syslog Message
Unable to retrieve and add alias for %s device %s.
- Parameters
deviceType (STRING): Type of device for which an alias addition failed.
deviceAddr (STRING): Address of the device for which an alias addition failed.
tapemc.alias.addOK
- Severity
NOTICE
- Description
This message occurs when a tape or medium changer alias is added successfully. Data ONTAP® might add aliases automatically at boot or when devices are added, if it determines that devices have no existing aliases.
- Corrective Action
(None).
- Syslog Message
Alias %s automatically added for %s device %s.
- Parameters
alias (STRING): New alias of the device.
deviceType (STRING): Type of device.
deviceAddr (STRING): Address of the device.
tapemc.alias.max
- Severity
ERROR
- Description
This message occurs when Data ONTAP® automatically adds a tape or media changer alias, and the new number of aliases exceeds the maximum number of aliases allowed. Automatic alias addition can occur when new devices are discovered, or when device connections are changed.
- Corrective Action
Delete any unused aliases with 'storage tape alias clear'.
- Syslog Message
Could not add alias for %s device %s. The alias count exceeds the maximum of %d aliases.
- Parameters
max (INT): Maximum number of tape and media changer aliases allowed.
tapemc.alias.threshold
- Severity
ERROR
- Description
This message occurs when Data ONTAP® automatically adds a tape or media changer alias, and the new number of aliases exceeds an internal threshold. The alias is added, but additional aliases might not be added until other aliases are deleted. Automatic alias addition can occur when new devices are discovered, or when device connections are changed.
- Corrective Action
- Syslog Message
Addition of alias %s for %s device %s totals %d aliases which exceeds threshold of %d tape/media changer aliases. The maximum number of aliases allowed is %d.
- Parameters
count (INT): Current count of tape and media changer aliases.
threshold (INT): Internal threshold for number of tape and media changer aliases.
