tapemc.unsupported events
tapemc.unsupported.allow
Severity
ERROR
This message occurs when a tape or media changer is detected that is not supported on this system, but its usage is not blocked. Use at your own risk.
Corrective Action
Remove the tape or media changer device, or use at your own risk.
Syslog Message
Attaching a tape or media changer device on adapter %s is not supported on this system.
AdapterName (STRING): Adapter name to which the tape device is attached.
