token.pit events
token.pit EMS events occur when ONTAP encounters issues associated with token point-in-time (PIT) file operations.
token.pit.file.create.info
- Severity
NOTICE
- Description
This message occurs when the token manager cannot create a PIT file in a volume. This can happen for the following reasons: insufficient space in the volume, unable to create the directory, or unable to set attributes.
- Corrective Action
(None).
- Syslog Message
PIT file creation in volume %s failed - %s.
- Parameters
volume_name (STRING): Name of the volume in which PIT file creation failed.
reason (STRING): Reason for the failure.
token.pit.file.deleted
- Severity
NOTICE
- Description
This message occurs when the PIT file of a volume is deleted. A new PIT file will be created automatically during the first 'token create' request for this volume.
- Corrective Action
(None).
- Syslog Message
PIT file in volume %s was deleted.
- Parameters
volume_name (STRING): Name of the volume in which the PIT file was deleted.
