ONTAP EMS reference
volcopy.dst events
volcopy.dst EMS events occur when ONTAP encounters issues associated with volume copy destination operations.
volcopy.dst.autoRestrictMsg
Severity
NOTICE
This event is issued when a vol copy start is issued on a volume which is offline.
Corrective Action
Vol copy start is issued on a restricted volume, use "vol restrict" to restrict the destination volume.
Syslog Message
Vol copy automatically restricting destination volume %s (currently offline).
dst (STRING): The vol copy destination volume
volcopy.dst.metadataOnly
Severity
NOTICE
This event is issued when a vol copy start operation is issued on a volume which is reverting its checksum state.
Corrective Action
(None).
Syslog Message
Metadata only vol copy from %s to %s.
src (STRING): The vol copy source volume
volcopy.dst.noMemory
Severity
ERROR
This event is issued when there is insufficient memory on the vol copy destination for the transfer to continue.
Corrective Action
(None).
Syslog Message
System is low on memory, aborting vol copy destination transfer.
(None).
volcopy.dst.revert
Severity
ERROR
This event is issued when a vol copy start operation has to revert the checksum state of the destination volume because the source and destination volumes have differing checksum states.
Corrective Action
No corrective action required.
Syslog Message
A vol copy transfer to destination volume %s has found that the source and destination volumes have differing checksum states. Data ONTAP is aborting the transfer and reverting the checksum state for the destination volume. After Data ONTAP displays a message showing the revert is complete, you will need to retry the operation. You can use the "vol status -c" command to see the progress of the reversion.
volcopy.dst.reverting
Severity
ERROR
Corrective Action
(None).
Syslog Message
Aborting vol copy transfer to volume %s because it is reverting its checksum state.
