      vsa.mlx events
vsa.mlx.nic.detach
- Deprecated
This event is replaced with vsa.sriov.nic.detach to rename the event and be generic.
 - Severity
NOTICE
 - Description
This message occurs when ONTAP® software is running as an instance in Azure and a NIC SR-IOV Mellanox (MLX) driver detach event is detected. ONTAP will continue to use the Hyper-V netsvc driver without the SR-IOV functionality for a short time. On HA configurations, unsynchronized logs might appear during this time, which will be resolved if a subsequent SR-IOV attach event occurs. If the SR-IOV attach event does not occur quickly, high-availability (HA) takeover might occur.
 - Corrective Action
(None).
 - Syslog Message
NIC SR-IOV driver detach event detected. On HA configurations, unsynchronized logs might result or an HA takeover might occur if SR-IOV remains detached.
 - Parameters
(None).
