vsa.sriov events
vsa.sriov EMS events occur when ONTAP® software running in the guest virtual machine (VM) detects an SR-IOV NIC detach event.
vsa.sriov.nic.detach
- Severity
NOTICE
- Description
This message occurs when ONTAP® software running in the guest virtual machine (VM) detects an SR-IOV NIC detach event. ONTAP will continue to use the Hyper-V netsvc driver without the SR-IOV functionality for a short time. On HA configurations, unsynchronized logs might appear during this time, which will be resolved if a subsequent SR-IOV attach event occurs. If the SR-IOV attach event does not occur quickly, a high-availability (HA) takeover might occur.
- Corrective Action
(None).
- Syslog Message
NIC SR-IOV driver detach event was detected. On HA configurations, unsynchronized logs might result, or an HA takeover might occur if SR-IOV remains detached.
- Parameters
(None).
