wafl.cop events
wafl.cop.flowcontrol.end
- Severity
NOTICE
 - Description
This message occurs when the system is out of the flow control mode which was earlier initiated as a high number of volumes were receiving modify operations concurrently beyond a certain threshold.
 - Corrective Action
(None).
 - Syslog Message
The node is out of the flow control mode which was earlier initiated as a high number volumes were receiving modify operations concurrently beyond a certain threshold (%lu).
 - Parameters
high_concurrency_flowcontrol_thres (LONGINT): System defined threshold beyond which high-concurrency flow control mode is triggered.
wafl.cop.flowcontrol.start
- Severity
NOTICE
 - Description
This message occurs when the system is in a very high concurrency mode; i.e., when a high number of volumes receive modify operations concurrently beyond a certain threshold. The system is automatically getting into a flow control mode, where it may hold ops on certain volumes for longer time in order to reduce high-concurrency related impacts.
 - Corrective Action
If the flow control situation is long-lived, and the delays are not acceptable, the concurrency level among the volumes need to be brought down by moving the volumes (preferably the ones encountering delays) out of this node.
 - Syslog Message
Very high number of volumes (%lu) are receiving modify operations concurrently. The node is in a flow control mode (threshold: %lu). As a result few volumes may experience higher delay in latency.
 - Parameters
concurrent_vvols_cnt (LONGINT): Number of volumes actively receiving modify operations.
wafl.cop.high.concurrency
- Severity
NOTICE
 - Description
This message occurs when the system is in high-concurrency mode; i.e., when a high number of FlexVol® volumes receive modify operations concurrently during a monitoring interval. High concurrency might cause degradation in performance.
 - Corrective Action
(None).
 - Syslog Message
A high number of FlexVol volumes are receiving modify operations concurrently. Interval (ms): %lu, Aggregate: %s, Frequency: %lu out of %lu times, Threshold criteria: more than %u FlexVol volumes were concurrently receiving modify operations, Distribution: %s.
 - Parameters
monitoring_interval (LONGINT): Duration of monitoring interval in milliseconds.
aggr (STRING): Name of the aggregate.
cp_above_vvol (LONGINT): Number of Consistency Points (CPs) with FlexVol volumes participating above the vvol_threshold value in this monitoring interval.
total_cp_in_interval (LONGINT): Number of CPs that happened in the monitoring interval.
vvol_threshold (INT): Minimum number of FlexVol volumes in a CP to call it a "highly concurrent CP".
histogram (STRING): A histogram [b1 : v1, b2 : v2, …, b8 : v8], where "b" represents bin ID and "v" represents count of the corresponding bin ID.
