ONTAP EMS reference
wafl.filecg events
wafl.filecg EMS events occur when a volume with file-based compression(either secondary compression or 8k/16K/32K adaptive compression) have nominal size greater than 300TB.
wafl.fileCG.vvol.size.exceeded
Severity
ERROR
This message occurs when a volume with file-based compression(either secondary compression or 8k/16K/32K adaptive compression) have nominal size greater than 300TB.
Corrective Action
(None).
Syslog Message
Nominal size of the "%s" volume exceeded the 300TB limit.
vvolname (STRING): Name of the volume.
