ONTAP EMS reference
wafl.fsa events
wafl.fsa.autosize.valid.fail
Severity
ERROR
This message occurs when enabling file system analytics on a volume with autosize enabled fails because there is insufficient space in the volume.
Corrective Action
Increase the volume size or free space on the volume until there is at least 8% free space for transitioned volumes or 5% for non-transitioned ones. Use the "volume modify" command to increase volume size.
Syslog Message
Enabling file system analytics on %s "%s" in SVM "%s" with "%s" usage while its size is "%s" fails because there is insufficient space.
volDesc (STRING): This message contains "transitioned volume" when the volume is a transitioned volume, otherwise, it contains "volume".
volName (STRING): Volume name.
vserverName (STRING): Name of the storage virtual machine (SVM) on which the volume resides.
spaceUsed (STRING): Space usage in the volume, represented in bytes.
volSize (STRING): Volume size, represented in bytes.
