wafl.nvlog events
wafl.nvlog.stats.createError
- Severity
NOTICE
- Description
This event is issued to indicate that the system is unable to create nvlog stats file.
- Corrective Action
(None).
- Syslog Message
Can't create nvlog replay stats file
- Parameters
(None).
wafl.nvlog.stats.writeError
- Severity
NOTICE
- Description
This event is issued to indicate the system is unable to write to nvlog stats file.
- Corrective Action
(None).
- Syslog Message
Nvlog replay stats fio_write failed
- Parameters
(None).
wafl.nvlog.versionFail
- Severity
ALERT
- Description
This message occurs when the nvlog version found in the NV log is not recognized by the current version of Data ONTAP®.
- Corrective Action
This might be the result of an upgrade or revert attempt after a dirty boot. If so, try the upgrade or revert after a clean shutdown. If the problem persists, or if this was not due to an upgrade or revert, contact NetApp technical support.
- Syslog Message
Could not replay WAFL NV log: nvlog format is of a prior or future release (%d, %d).
- Parameters
version (INT): WAFL® NV log version in the NV log.
myversion (INT): Kernel WAFL NV log version.
